Ansys Learning Forum › Forums › Installation and Licensing › Ansys Free Student Software › Toolbox only showing Fluid related analysis systems › Reply To: Toolbox only showing Fluid related analysis systems
December 7, 2021 at 1:33 am
kipoon
Hello Saad21011996
I had the same issue as you (only CDF apps were shown in the Workbench) and I managed to solve the problem. Try running Fluent from the workbench. If you get a license error -88309 then we have the same issue. I am also running windows 11.
This is the post I originally made in the Ansys forum and this is where I solved the issue from the Flexera forums. Hope it helps
