Ansys Learning Forum Forums Discuss Simulation General Mechanical Generalized Garofalo Creep Law in ANSYS Engineering Data Reply To: Generalized Garofalo Creep Law in ANSYS Engineering Data
Andrew_tan
Thank you for your response. Yes, table III is from reference paper. As can be seen, the C2 is in the unit of MPa^-1. If I am using m, s, K, N reference unit in ANSYS, I have inputted C2 as 6.2653E-8 as Pa^-1 instead of 0.062653 MPa^-1.
May I know is that correct?
