Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Lumerical Python API doesn’t Use the full capacity of the assigned CPU in HPC › Reply To: Lumerical Python API doesn’t Use the full capacity of the assigned CPU in HPC
Lito
How did you set your resources? Have you tried running with 1 node using all available cores on 1 node?
