Ansys Learning Forum Forums Discuss Simulation Fluids Partitioning with journal file Reply To: Partitioning with journal file
With around 1 million cells and non-conformals for sliding mesh I'd not go over about 10 partitions for efficient use of the cores. You'll still see speed up beyond that.
Re the two commands, why are you partitioning and then setting the partition across boundaries? Also, whilst journals are very powerful it's usually easier to set up a model locally, partition manually and then send it off to the cluster to run.
