Ansys Learning Forum Forums Discuss Simulation Fluids Named Expression Syntax for TUI Script Reply To: Named Expression Syntax for TUI Script
Build a simple case locally and use that to experiment. Can you set up a model locally using the GUI and then send it to the cluster? TUI scripts are incredibly powerful but do require a higher level of experience to use well.
