Ansys Learning Forum Forums Discuss Simulation Fluids Zero thickness wall inside the domain Reply To: Zero thickness wall inside the domain
The thickness cannot be smaller than a cell, I'll leave you to try it out. Yes, create a body with a "sensible" thickness and assign one surface as a wall: the others should either be left alone or defined as interior.
