Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Coordinate system at each point of a surface › Reply To: Coordinate system at each point of a surface
October 27, 2021 at 2:24 pm
HI
See the nrotat command that rotates the nodal coordinate system as needed. There is though a limit on how many coordinate systems you can define I imagine, so if you have 1 million nodes and need so many coordinate systems .
This post is also useful if you use WB mechanical
Hope this helps
Hope this helps
