Ansys Learning Forum Forums Discuss Simulation Preprocessing Boolean Operation Failed Reply To: Boolean Operation Failed
Aniket
Check the default value of tolerance for boolean operations through BTOL, STAT command.
Provide a tolerance value about 1/20th to 1/10th of the minimum KPT distance using the BTOL command.
-Aniket
