Ansys Learning Forum Forums Discuss Simulation General Mechanical Orientation of the layer application for curved surfaces in acp (pre) Reply To: Orientation of the layer application for curved surfaces in acp (pre)
Sean Harvey
Ok, since you don't have access to the customer portal, can you please check for the help shortcut in the installation? If you go to the start menu, then Ansys Student version folder, there should be a link to launch help. You will search for
2.1.15.1.3.1. Mesh Morphing
In the ACP User's guide.
Can you confirm?
Regards Sean
