Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Parallel and Partitioning › Reply To: Parallel and Partitioning
July 28, 2021 at 1:50 pm
It's usually enough. You can set the options to use a different scheme and add load balancing but I'd leave those alone until you know why you want to change from the default.
