Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Power Ferrite Core Loss Units Maxwell › Reply To: Power Ferrite Core Loss Units Maxwell
July 27, 2021 at 7:39 pm
I've solved the issue. f must be in Hz, B in Tesla. P is in W/m^3. This means that core loss parameters (in particular the constant term Cm) must often be changed from their given values on a datasheet in order to give accurate results.
