Ansys Learning Forum Forums Discuss Simulation Fluids Vertex average Reply To: Vertex average
The best way to judge is to create the point and then use the surface integrals to check the value of the various options: you need to initialise first. Then pick the one that makes sense. Assuming the mesh is sufficiently refined, vertex mean, max and min should be reasonably close.
