Ansys Learning Forum Forums Discuss Simulation General Mechanical The Result Data for FSUM is not contained in the result file Reply To: The Result Data for FSUM is not contained in the result file
christian.katsavos
Hello IC1 thanks for your help, but I dont understand how to make available the options visible in your "Details of "Analysis Settings". Have a look at mine:
As you can see, for me Save MAPDL db option (as many others) is not visible... I've gone to "Options" and then to "Analysis Settings and Solution". I've selected "YES" in "Save MAPDL Database", but it is still not visible inside the Analysis Settings window".
Any tips to make all those options available?
Thanks so much Christian
