Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Solution reload › Reply To: Solution reload
February 9, 2021 at 4:40 pm
You'd need to use execute commands to read files at intervals, and the DPM Summary can be converted to an injection file. We're not permitted to give too detailed a response, but using the manual the steps should be fairly straightforward if not overly easy. n
