Ansys Learning Forum › Forums › Discuss Simulation › Systems › 1D Heat Conduction in a Rectangular Rod › Reply To: 1D Heat Conduction in a Rectangular Rod
karthik.remella
Administrator
You will not be able to do a 1D heat transfer analysis on Ansys. It is possible to assume a 2D domain and apply boundary conditions on your rectangular rod (assume adiabatic at the two opposite ends) and for a 1D unidirectional heat transfer. This can be achieved in Ansys.
However, for a pure 1D analysis - please refer to a rudimentary heat transfer textbook, which will give you the analytical solution.
Thank you.
Best Regards,
Karthik
