Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Implement a do loop in Ansys Workbench 16 for uniform circle shaped pressure load › Reply To: Implement a do loop in Ansys Workbench 16 for uniform circle shaped pressure load
All steps:
H_Flux=1000
Radius=0.003
Step 1:
/prep7 ! Enter into /prep7 as ET and ESURF are valid only in /PREP7
et,101,152 ! Create a new element type for SURF152
cmsel,s,surface1 ! Select nodes on a face via Face named selection
type,101 ! Set the element type as 101
esurf ! Create surface effect elements on the selected nodes
allsel,all ! Select everything back
/solu ! Re-enter /SOLU
wpcs,-1,0 ! WP @ GLOBAL ORIGIN
wpof,,0 ! OFFSET WP ALONG ITS Y AXIS (i.e. provide current position of center of circle along Y axis)
cswp,11,1 ! DEFINE Cylindrical COORDINATE SYSTEM @ WP ORIGIN
esel,s,ename,,152 ! Select SURF152 elements
sfed,all,,hflux ! Delete old flux if any
nsle ! Select nodes attached to selected SURF elements
nsel,r,loc,x,0,radius ! Select nodes within radius of circle, 0.005m
csys,0 ! Set CSYS back to global
esln,r ! Select SURF elements attached to the nodes within the circle
sfe,all,,hflux,,H_flux ! Apply hflux based on your calculation at the said time
allsel,all
outres,all,all
Step 2:
wpof,,0.01 ! OFFSET WP ALONG ITS Y AXIS (i.e. provide current position of center of circle along Y axis)
allsel,all
outres,all,all
