“Mesh is self-intersecting” error using AutoSkin tool
    • jcm169
      I am receiving a set of errors when attempting to using the AutoSkin tool to smoothen the surface of my model (see pictures attached). nI used this technique on a similar model for my other CFD simulation, and the AutoSkin tool worked completely fine with no errors occurring. Is there any way to fix this in SpaceClaim?.
    • Karthik Remella
      Administrator
      Can you try and use this skin surface tool on a smaller portion? In this region, the curvature is pretty high. This could be the reason for this error message.
      Dissect this region into multiple smaller regions and attempt to use the tool. Let me know how this works.
      Karthik
  • The topic ‘“Mesh is self-intersecting” error using AutoSkin tool’ is closed to new replies.
