CHOOSING THE SIMPLE AND COUPLED ALGHORITHME IN FLUENT !
    • DJENDARA
      I need to simulate an UDS with fluid dynamics equations, but it need to use the SIMPLE algorithme FOR my UDS and COUPLED for the fluid equations (separatly) since it is not possible in FLUENT R1 2021 how can i do for solving this probleme ?nI compute the UDS explecetly (by using I/O UDF) but this method cost a lot of time , i ask if it will possible in the next versions of FLUENT ?nBest regards thankyou !n
    • Keyur Kanade
      As far as I know you can not use different schemes.n/https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v202/en/flu_ug/flu_ug_solution_methods_task_page.html%23flu_ug_solution_methods_task_pagenRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
    • DJENDARA
      I want to compute each equation (between UDS and fluid equations )with an specified algorithm in one session in fluent !n
      Check the theory for pressure based coupled solver, I think pressure & velocity are coupled, some of the rest of the equations aren't. n
    • DJENDARA
      I observe that Fluent solve all equations together since the number of iteration augmente when I add my uds the computational matrix augmente nAnd in my simulation I want to use the simple algorithm for my uds and coupled for fluide equations (pseudo transient) when I solve my uds by this algorithm it give me unwanted result so I think that the solution here is :nFluent let the possibility to compute each equation separately with proper algorithm and matrix in same session.nOr I export the solution from other session of fluent i.e I lunch fluent for the fluid in part and I lunch fluent session for my uds with simple algorithm in other part where the result of this later will be exported like a source term for fluide equations.nPlease help me nBest regardsn
      The UDS isn't solved as part of the coupled section https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v211/en/flu_th/flu_th_uns_scheme.html nAs I don't know what you're trying to do it's difficult to suggest anything. If a scalar is being incremented every iteration it tends to suggest the logic is off somewhere or you're using the wrong macro. n
Viewing 5 reply threads
  • The topic ‘CHOOSING THE SIMPLE AND COUPLED ALGHORITHME IN FLUENT !’ is closed to new replies.
