Why can’t DPM be deactivated during simulation set-up?
    • mcgrat25
      I was completing an MPM model in Ansys but had decided to go back to the geometry and meshing phases to make some changes to the model's geometry. I am currently trying to re-run the model as a basic steady simulation before I will re-run it as a transient MPM simulation. The issue I am running into is that I cannot seem to be able to deselect a DPM injection within initialisation:
    • Amine Ben Hadj Ali
      Remove Injection from MPM before disabling it and try again. n
      If the DPM model isn't set to interact then don't worry about it. As Arraynotes, it's set as on if there is an injection, even though it's not doing anything. n
    • mcgrat25
      and ,nThanks for getting back to me. I've deleted both the MPM & DPM injections and deactivated both of the models, but still get the below error message during simulation:nI do have multiple particle-tracks set from when MPM was active - would I have to delete these? I'd rather not, as I want to go back to MPM afterwards and it's quite time-consuming to recreate all of these.n
      Please remove anything related to particle and particle tracks: objects, contours, animation. And try again. If the issue persists please let me know your university email address.n
Viewing 4 reply threads
  • The topic ‘Why can’t DPM be deactivated during simulation set-up?’ is closed to new replies.
