TAGGED: deformation, result-visualisation, static-structural
January 26, 2021 at 5:55 am
psansys
SubscriberDear Experts,
I performed a static structural analysis of an assembly and the image was the result(deformation). The max. deformation is just 5.5 microns and the clearance (non-deformed) between the tub and the part inside is more than 15 mm. What would be the explanation for the deformation showing the parts projecting out ? Is it just an exaggerated representation ?
January 28, 2021 at 4:51 pmAniket Chavan
Forum ModeratorWhat is the results scale that you are using? Try changing it to true scale and see if this happens? https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v201/en/wb_sim/ds_Context_Toolbar.htmln-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning ForumnJanuary 29, 2021 at 2:31 ampsansys
SubscriberThank you so much! It was in auto scale.nViewing 2 reply threads- The topic ‘solution graphics seems unrealistic’ is closed to new replies.
6450
