January 18, 2021 at 10:37 pm
kitzo2
SubscriberJanuary 19, 2021 at 6:35 pmicellb1
Ansys EmployeeHi, nThere are no error messages but warnings of not converge. You can just increase the maximum number of adaptive pass in your analysis setup to solve this warning.nAlso, may I ask if this the same project to that posted in another question Trying to animate magnetic field simulation for wireless power transfer?nIf you right click on result --> solution data, click matrix tab. Can you see any value if you switch to R,L or inductive coupling coefficient? I'd also like to see a screenshot of this window if possible. nJanuary 19, 2021 at 9:34 pmJanuary 20, 2021 at 12:26 amicellb1
Ansys EmployeeHi, nFrom your Message Manager the design variation offset='2.5mm' is probably not analyzed so that's why there is no result for it. Instead of right clicking parametrics-->analyze, try going to Simulation tab on the top tool bar, then click Analyze all. Check the result again after analysis finishes. nAlso, make sure to check save fields and mesh in parametrics (Video 2:57) this time before analyzing. nJanuary 20, 2021 at 2:33 pmViewing 4 reply threads- The topic ‘Adaptive passes did not converge based on specified criteria’ is closed to new replies.
5889
1306
