January 15, 2021 at 11:36 am
MickMack
SubscriberHi,
I have used the fill and blend functions to create surfaces to be used to represent a concrete floor between four beams.
Can the automatically created surface shown below (highlighted in tree) be used to represent a concrete floor? Will the surface be connected to the beams in the analysis?
January 16, 2021 at 11:27 amMickMack
SubscriberThe answer is yes and if the perimeter of the surface is changed the beams (created on the edges) will also adjust in responsenMarch 15, 2021 at 9:38 amLachlanConsiden
SubscriberI agree with you. This method is not popular, but it can be used. See the options for designing a concrete floor here. nMarch 22, 2021 at 3:54 pmMickMack
SubscriberArrayThe link you provided is a link to a website for a floor surface contractor, this does not seem consitant with your comment, i.e See the options for designing .....nViewing 3 reply threads- The topic ‘Can an automatically created surface be used to represent a concrete floor?’ is closed to new replies.
4783
1565
1386
1242
