Ansys Products
Ansys Products
APDL cannot be started
    • VitZam
    • George Karnos
      Hello VitZam,nAre you running on 1 machine (DESKTOP-5MLBFI7)nWhat is the output from opening a DOS command prompt and typing in:nping DESKTOP-5MLBFI7nThe error looks to be coming from Intel MPI.nWhat happens if you change it to use IBM MPI?nBest,nGeorge
    • VitZam
      This is what the command line response looks like.nSomehow I don't know where to change IBM MPI.nThanksn
    • George Karnos
      Can you post a screen shot of the Project page?nWhat is the output from opening a DOS command prompt and typing in:nping -4 DESKTOP-5MLBFI7nnI see that when you ping the machine, it uses IPv6.nI am wondering if this may be interfering. pinging usually returns IPv4.
    • VitZam
      Do you think this Project page? nThis is what the command line response looks like.nI also did not say that I use a VPN for the license, specifically the Cisco AnyConnect Secure Mobility Clientn
Viewing 4 reply threads
  • The topic ‘APDL cannot be started’ is closed to new replies.
