January 9, 2021 at 12:19 pm
Evgenii_K
SubscriberHi guys, I am merging the shell and the beam using the mesh connection group, after merging the beams rotate and ANSYS gives the error - The Quad Mesher failed on one or more faces during mesh connections. I ask for help how to solve this problem !? When merging, the geometry should not change, but mine does.
Model before unification:
January 14, 2021 at 8:31 amAniket Chavan
Forum ModeratorDo you absolutely need to merge the nodes? Can you use MPC bonded contacts instead?n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning ForumnJanuary 16, 2021 at 11:39 amEvgenii_K
SubscriberDo you absolutely need to merge the nodes? Can you use MPC bonded contacts instead?-AniketHow to access Ansys help linksGuidelines for Posting on Ansys Learning Forum/forum/discussion/comment/103017#Comment_103017
Thanks, I will try to do it, but I avoid contacts because of the large model.nJanuary 16, 2021 at 7:47 pmViewing 3 reply threads- The topic ‘Mesh Connection Group’ is closed to new replies.
5899
1306
