November 13, 2020 at 4:25 am
17rt654
SubscriberHello, based on the question above. What does my simulation have problems with?. -
November 13, 2020 at 8:03 am
jonsoln
SubscriberHi!nCheck the solution file to see what error caused the solver to fail. This will give you more information about what might be the issue. To open the solution file go to Solution information and select Solver output. Scroll down towards the bottom or search for Error.n
- The topic ‘The solver engine was unable to converge on a solution for the nonlinear problem as constrained.’ is closed to new replies.
1890
1419
1304
