different x,y,z values for profile export from fluent
    • soloviev
      I am just wondering why the values for x,y,z vary in a profile export directly from Fluent (see photo for example). Which are more accurate?
      Thanks,
      Alex
    • Konstantin
      Fluent reads a profile that you supply and then interpolates to cell face centroids. Once you export, you get this interpolated profile. n
    • soloviev
      Thank you! So if we were going to use this profile as a boundary to base other data off of, that will be imported back into fluent, which are better to use? n
    • Konstantin
      Good question. I'd say use Fluent's x, y and z locations as this will minimize interpolation errors. n
    • soloviev
      Thanks! Just to clarify those values would be the ones on the right, correct?n
    • Konstantin
      yes, those are face cell centroids where data will be interpolatedn
    • soloviev
      Thanks!n
Viewing 6 reply threads
  • The topic ‘different x,y,z values for profile export from fluent’ is closed to new replies.
