November 3, 2020 at 3:15 am
Lugia_06
SubscriberHi everyone,
November 3, 2020 at 10:34 amAmine Ben Hadj Ali
Ansys EmployeeYou have single velocity field so you cannot get the velocity field of particular phase: all phases moves at the same velocity.nNovember 3, 2020 at 5:04 pmLugia_06
SubscribernSorry I still cannot understand the single velocity field part, I was thinking Fluent would take water velocity and air velocity separately, and I think in physical world it is truth that the water droplet should travel faster than air due to gravity? Would you please explain further on this?nBest regards,nLugia_06nNovember 3, 2020 at 7:17 pmAmine Ben Hadj Ali
Ansys EmployeeNo. If you using VOF or mixture model without slip a single momentum field is solved. nViewing 3 reply threads- The topic ‘Water phase velocity and multiphase assymetric model mixture axial velocity definition’ is closed to new replies.
4893
1587
1386
1242
