October 31, 2020 at 10:10 pm
Luigi0
SubscriberHi ,
I want to simulate acoustophoresis phenomena.Â
My system is composed by a fluid domain surrounded by a mechanical structure and a piezoelectric transducer. The fluid domain has an inlet where the fluid (water) and particles are inserted.
November 2, 2020 at 10:54 amLuigi0
SubscriberMight could be a problem in the geometry definition?nNovember 2, 2020 at 9:36 pmSurya Deb
Ansys EmployeeHello, nIn CFD Post, do you see all the respective domains properly? Do you see separate Piezo and Silicon domains/zones?nIf one of them is missing, then please double check the geometry definition.nRegards,nSuryanNovember 3, 2020 at 2:16 pmLuigi0
SubscriberHello Array,nthanks for your answer. In CFD post I don't see the separation of piezo and silicon domains. Moreover I checked the geometry definition, and it seems ok. I created different parallelepipeds, each one for each materials, and I use the add frozen option in design modeler. So I don't know why I don't see the separation in CFD post.nNovember 3, 2020 at 4:53 pmAmine Ben Hadj Ali
Ansys EmployeeCan you list the zones in Fluent? Can you check the tree of domains in Post? How many zones are u seeing?nNovember 4, 2020 at 4:58 pmLuigi0
SubscriberIn Post I see the the fluid zone (part fluid) with different boundaries (bottomwall,...) and it's ok, then I see the solid part (default domain) but the solid part comprehend glass, silicon and piezo layer but there is no option to select one of them individually.n
n
November 4, 2020 at 6:20 pmAmine Ben Hadj Ali
Ansys EmployeeOkay all solids are encompassed within single domain. That might be a limitation of Post processing. You might separate by using clipping or iso volume. nis this a known issue with processing structures in Post?nNovember 4, 2020 at 9:20 pmpeteroznewman
SubscriberI don't use Post much so don't know what to expect here.nIt is worthwhile renaming your Case to get rid of so many Copy of words.nNovember 10, 2020 at 4:11 pmLuigi0
SubscriberThanks Array, but what does it means separate by using clipping or iso volume?nViewing 8 reply threads- The topic ‘Geometry differences in CFD post’ is closed to new replies.
4668
1550
1386
1230
