Ansys Products
Ansys Products
License issue for Fluent
    • abhijeetthaker
      Hello!
      I am trying to take license from the server machine for Ansys Fluent 2019R3. We are using Ansys Academic licenses. When I configure the Client ANSLIC_ADMIN Utility for license server and check the status I am able to connect the server machine,
    • ANSYS_MMadore
      Can you try renaming %APPDATA%\Ansys\v201 to v201.old and %APPDATA%\Ansys\v202 to v202.old and see if that has any impact?nThank youn
    • abhijeetthaker
      Hi, I did that by renaming like you have mentioned and also, by removing the folder completely. But the problem is the same. n
    • ANSYS_MMadore
      Can you please share the text of these files?n%TEMP%\.ansys\licdebug.FLUENT_SOLVER.195.outn%TEMP%\.ansys\licdebug.FLUENT_SOLVER.201.outn%TEMP%\.ansys\licdebug.FLUENT_SOLVER.202.outnFrom the License Server Machine, please share the contents of the ansysli_server.log file.nn
  • The topic ‘License issue for Fluent’ is closed to new replies.
