August 31, 2020 at 6:57 pm
Stat
SubscriberHi everyone,nA problem that I occasionally meet when running static structural analysis is when I try to replace the geometry of the model. Whether I replace a part of the geometry with a new one or the whole geometry, while the new geometry seems to be loading up, when the loading is over, the geometry does not appear on mechanical and has question-marks under the Geometry sector.nDoes anyone know the reasoning behind this and are there any suggestions?n -
September 2, 2020 at 1:42 am
Karthik Remella
AdministratorPlease take a look into the geometry and see if the Material Property values are assigned properly.nIf this does not help, please take a screenshot and post it here in your post so can help you.nThanks.nKarthikn -
May 25, 2023 at 2:54 pm
Matthias Duve
SubscriberHi, have a similar issue.
I want to replace only one geometry (part) in an assembly in mechanical. I only seem to be able to replace the whole assembly with the standard prompts. If I do so, all external points, connections, joints eg only have question marks on them afterwards and won´t work. Event on the parts that are exactly the same than before.
Any ideas how to solve this?
Thanks a lot!
- The topic ‘Error when replacing the geometry’ is closed to new replies.
1510
1386
1209
