TAGGED: cfd-post, dpm-model, post-processing, transient-analysis
August 5, 2020 at 8:40 am
gihrs
SubscriberHi, nI'm new into DPM simulation. Currently, I'm doing a coughing simulation using DPM, transient-state. After finishing simulation and export particle data history (in .XML extension), I try to import it in CFD-Post to visualize. But, there isn't any particle track imported (even after select the file and click 'OK'). nI also try using particle-track graphics in FLUENT, but it only shows the latest time step particle location. nAnyone knows about this problem? n -
August 5, 2020 at 9:22 am
Amine Ben Hadj Ali
Ansys EmployeeCan you add a screenshot of what you are seeing and trying to in CFD-Post?n -
August 5, 2020 at 9:26 am
Amine Ben Hadj Ali
Ansys EmployeeAnd how are you exporting from Fluent?n -
August 5, 2020 at 10:43 am
gihrs
SubscriberHello Dr. Amine,This is how I export particle data from Fluent. EXPORT - Particle History Data - WRITE.n
nAnd this one is how I import in CFD-Post. But even after I click OK, there isn't any Particle Track data under 'User Locations and Plots' tree. n
nWhat I want to visualize, since currently I'm doing coughing simulation inside a room, is particle dispersion for every 5sec inside the room. n
August 5, 2020 at 12:13 pm
Amine Ben Hadj Ali
Ansys EmployeeSo you are exporting it only once. That is not enough if you doing transient particle tracking where you need that the XML file get filled with all particle tracks for the whole simulation time. You need to go for export during calculation.n -
August 5, 2020 at 1:01 pm
gihrs
SubscriberYes, Dr. Amine.nActually, I consider to do automatically for each time-steps using this step.n
nAnd this is the XML result (complete for all the time-step).n
nBut, also after I import to CFD-Post, there isn't any particle track plots. Am I using wrong variables? n
August 5, 2020 at 1:11 pm
Forum ModeratorIf you plot the particles in Fluent are they working there? Note, as it's a transient model you'll see dots rather than the continuous tracks.n -
August 5, 2020 at 1:15 pm
August 5, 2020 at 1:33 pm
Forum ModeratorYes. You'd need to plot at the step of interest or have saved the data file and reload it. n -
August 5, 2020 at 4:26 pm
Amine Ben Hadj Ali
Ansys EmployeeCan you read case and data file before reading the xml file?n -
August 6, 2020 at 5:22 am
gihrs
SubscriberIn that case, I found this problem. I put the case and data file in /nBut, it turns out that some error happened. (like this screen-capture below)n
n
August 6, 2020 at 5:54 am
Amine Ben Hadj Ali
Ansys EmployeeThat is another problem: do you have case and data under the directory you want to read from? Is existent?nWhich version are you using? nI can confirm that I am able reading transient XML data into CFD-Post with the actual release.nYou might also create a dummy quick running case and try doing similar steps and reading XML: will that work? (Check if the issue case dependent)nn -
August 6, 2020 at 7:31 am
gihrs
SubscriberYes, Dr. Amine, I'm using ANSYS R1 2020 right now. nActually, I have the case and data under /, but it always give ERROR window even for .cas file or .datn
nSo, is it related to the XML reading problem and its error? n
August 6, 2020 at 11:10 am
Amine Ben Hadj Ali
Ansys EmployeeMaybe because of the naming of your directory starting with #. Please move to a neutral directory and try again. Also try to read the last dat file and not the first one. Please use for this testing CFD-Post outside of the Workbench.nn -
August 10, 2020 at 2:08 am
gihrs
SubscriberHi, Dr Amine. nYes, I removed the '#5' in the name file. And, it works!nThank you for your guidance!n
Viewing 14 reply threads
- The topic ‘Why particle track is missing for Post-processing on transient DPM simulation?’ is closed to new replies.
1587
1386
1242
