August 3, 2020 at 3:16 am
prajput
Can I highlight a node or an element by its ID to locate it in the model?
August 3, 2020 at 3:25 am
Karthik Remella
AdministratorYes, you can insert a Named Selection and select the Scoping Method as Worksheet. In Worksheet, you have option to select a node or an element based on Node ID or Element ID criteria. Once you generate this Named Selection and select it, it will highlight the corresponding entity in the graphics. It is advisable to use Wireframe Display option to see it easily. -
August 3, 2020 at 7:46 am
prajput
Are there any other ways to highligh the nodes and elements?
August 3, 2020 at 10:08 am
Karthik Remella
AdministratorTo select the mesh by ID go to Selection Tab --> Select by Mesh ID... --> then enter the individual ID or a given range. -
August 3, 2020 at 10:40 am
prajput
Another way is go to Display Tab --> Preferences Annotation --> Mesh Display --> Select Node numbers and/ or element numbers and then Apply
Viewing 4 reply threads
- The topic ‘Can I highlight a node or an element by its ID to locate it in the model?’ is closed to new replies.
1891
1419
1305
