Preprocessing
Preprocessing
How to get Named Selection or Parameters from SpaceClaim to Mechanical based on certain pattern?
    • prajput
    • Karthik Remella
      Administrator
      For this, you can go to FIle/SpaceClaim Options/FIle Options/Workbench and there you can set Named Selection Key or Parameter Key for selective pattern.
    • prajput
      How can I add multiple parameter keys?
    • Karthik Remella
      Administrator
      You can add the multiple parameter keys separated by semi-colon.
    • Gary Wang
      https://help.spaceclaim.com/2015.0.0/en/Content/ANSYS_NamedSelections.htm
      FYI
Viewing 4 reply threads
  • The topic ‘How to get Named Selection or Parameters from SpaceClaim to Mechanical based on certain pattern?’ is closed to new replies.
