August 29, 2026 at 5:31 am
Dennis Chen
SubscriberHello, I want to ask if there's any instruction on how I can modify the default behavior of workbench LSDYNA in terms of how it writes out input files.
For example, if I want to use a material model by inserting a lsdyna commnand in the geometry section, it doesn't allow me to put the load curve in that same command file, I have to insert it under lsdyna analysis setting.Â
I like to modify the input write-out logic such that load curve can be inserted in the command under geometry.
There are many other examples, is it possible?
Viewing 0 reply threads
