Ansys Products
Ansys Products
Siwave Set Equipotential
    • um971
      I'd like to ask whether there is a way in SIwave to batch set nets or pins as Equipotential, either manually or through scripting.
    • Takeshi Itadani
      Bbp_participant
      You can group nets that are intended to be at the same potential by selecting the menu option **Tools > Create Manage Pin Groups...**.
      Once the settings screen opens:
      *   Select the target component from **Part Name**.
      *   Select the target nodes from **Nets**. You can remove nets you do not wish to include in the pin group using **Edit Pin Group**.
      *   Create the pin group using **Create Pin Group**. Finally, click **OK** to close the settings screen.
      This changes the on-screen display, connecting the nets within the same pin group with lines.
      During analysis, these grouped pins are treated as having the same potential.
      These pin groups can be configured as ports.
