August 16, 2026 at 7:02 am
Prathamesh Kothawale
Bbp_participantI'm working through the "HFSS 3D Layout — Getting Started" course,ÂWorkshop 01.1 (Connector on Board Simulation), using the archiveÂBoardESD6.aedtz from the HFSS_3DL_GS_2023R1_EN_WI1.0_SimFiles package.ÂSoftware: Ansys Electronics Desktop Student 2025 R2.4 (Build: 2025-11-06)ÂSteps taken:1. Restored the archive via Desktop > Restore Archive2. Saved as BoardESD6.aedt in a new working directoryÂResult: The Circuit design "ConnectDT (Terminal Network)" loadedÂsuccessfully, but the HFSS 3D Layout design "3DL_ESDPCB" did notÂappear in the Project Manager tree at all.ÂMessage Manager output:"Unable to open some designs from the project file. This may beÂcaused by insufficient licenses or unsupported student version forÂthe types of designs in the project, or by a corrupted project file."Â"Component 3DL_ESDPCB references design 3DL_ESDPCB which is missing.ÂIt would be best to remove the component."ÂI have not saved over the file, per the warning shown.ÂSince the workshop files are dated for 2023R1 and I'm on 2025R2.4,ÂI suspect a version/kernel compatibility issue. Is there an updatedÂversion of this workshop file compatible with 2025R2, or a migrationÂstep I should follow? Thanks.
Viewing 0 reply threads
