July 13, 2020 at 4:10 pm
July 13, 2020 at 5:28 pm
user deleted
SubscriberThank you, what is external work in this case? energy of my object is 20kj (with the mass and speed it has) I also have added mass layer (water). Thank you again.
July 13, 2020 at 7:16 pm
Wenlong
Ansys EmployeeDo you have any external load applied to the system? The work external load did to your system will be the external work. If you have a controlled displacement or velocity or acceleration, then at the controlled boundary conditions there will also be external load acting on the system.Â
If you only have initial condition (like velocity) then leave the system unloaded, then your external work will be zero.Â
You can plot the external work from row 9 in the LS-Prepost window you shared.Â
Wenlong
July 13, 2020 at 7:27 pm
Wenlong
Ansys EmployeeHi,
I wasn't right previously. I double check and found that, in LS-DYNA (https://www.dynasupport.com/howtos/general/total-energy):
Total energy reported in GLSTAT (seeÂ
*DATABASE_GLSTATÂ ) is the sum of
- internal energy
- kinetic energy
- contact (sliding) energy
- hourglass energy
- system damping energy
- rigidwall energy
So there can be other energy components that contribute to your total energy.Â
Please note that in Ansys Explicit Dynamics (using Autodyn solver), the total energy is only the sum of internal and kinetic energy (https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/wb_sim/ds_Energy_Results.html?q=energy%20error%20explicit).
Wenlong
================ Note ====================
If you have trouble opening the links I attached, please see the first useful link below
Useful Links
- How to access Ansys Online Help Document
- How to show full resolution image
- How to use Google to search within Ansys Student Community
July 13, 2020 at 7:30 pm
July 13, 2020 at 7:44 pm
Wenlong
Ansys EmployeeHi,Â
Sorry I was wrong about the external work. It is not included in Total energy. My most recent reply was correct about total energy.Â
Then the reason your plots are like this is probably caused by contact energy because it can be negative (https://www.dynasupport.com/howtos/general/contact-energy) This website describes why it is negative in some cases, and also shows suggestions about how to alleviate negative contact energy.Â
Wenlong
July 13, 2020 at 8:11 pm
user deleted
SubscriberMay I ask you where to find these setups if you have a chance to answer. Thank you
- Set contact controls back to default except setÂ
SOFT=1Â andÂIGNORE=2Â (Optional Card C). - For contact of sharp-edged surfaces, setÂ
SOFT=2 on Optional Card A.  SOFT=2 is also referred to as segment-based contact and so is not applicable to any NODE_TO_SURFACE type contacts. Two important companion variables to SOFT=2 are SBOPT and DEPTH.Two important companion variables to SOFT=2 are SBOPT and DEPTH.
SBOPT: Unless sliding between surfaces is prevalent, set SBOPT=3. When sliding is prevalent, set SBOPT=5.
DEPTH:Â DEPTH=13 or 23 is recommended unless shell edge-to-edge contact must be considered, in which
case set DEPTH=25 or 35.
Please note that SOFT=2 contact carries some additional expense as compared to SOFT=0 or 1,
particularly using nondefault values of SBOPT or DEPTH.
July 13, 2020 at 8:34 pm
July 14, 2020 at 7:25 am
July 15, 2020 at 7:43 am
user deleted
SubscriberHi, this is a bit out of topic and sorry for being so stupid, but I have several soft in my input file and ignore only one. I have 4 bonded contacts (for other parts) and 1 frictionless contact for the dropped object. I do not understand link/dependence between of them. Would you please advise? Thank you.
July 15, 2020 at 2:35 pm
July 16, 2020 at 1:38 pm
July 17, 2020 at 6:36 am
- The topic ‘Kinetic, internal and potential energies’ is closed to new replies.
6455
