July 2, 2020 at 10:46 am
PrabhuManickam
SubscriberHi,
I am doing a 1D analysis of beam with uniformly varying load. The problem I am facing here was I cant able to give UVL load.Â
Uniformly Distributed Load is given by Pressure. But Uniformly Varying load how we give in Ansys workbench. Can anyone help me to solve this problem?
Please little urgent.Â
Thank you in Advance,
Prabhu M.
July 2, 2020 at 12:18 pm
peteroznewman
SubscriberÂ
Do you mean a triangular shape? If the beam is along the X axis and the beam is of length L, and the load starts at P at x=0 and is 0 at x=L, is that what you want? If so, you can have a table or formula for load as a function of X. Just change the Independent variable from Time to X and you can define a spatially varying load.
If this answers your question, please mark the Is Solution link below, or ask a followup question.
July 11, 2020 at 7:13 am
PrabhuManickam
SubscriberHi, peteroznewman,
Actually the result is not coming,
1) My question is
I want to apply a load in a downward direction which is perpendicular to the axis of the beam or bar.
2) If I apply the UVL in the direction of X, we get the result in deformation
Load Applied
Deformation Result
Shear Force & Bending Moment Diagram
The value shows zero. Because load applied in Axial Direction.
So, If we change the load in Y or Z Direction. The result is not coming. Even deformation also shows zero
So Finally other than X Direction we cant able to apply load in other directions. Can you please check and give me the result.
July 11, 2020 at 11:06 am
peteroznewman
SubscriberThe tangential direction to a straight line is axial. You are applying an axial load, stretching the beam along the X direction.
As you noted in this post, you can't assign the Independent Variable to a coordinate direction for a Line Pressure when it is set to Components.
You will have to use Nodal Force to get a triangular shape of load. That is tedious because you have to make a Named Selection for each node and create a Nodal Force for each node.
July 11, 2020 at 3:37 pm
July 11, 2020 at 3:38 pm
peteroznewman
SubscriberIf you are clever, you can learn to code in APDL and write a script to assign the correct load to each node using the node's coordinate value. I haven't yet learned to do that.
July 13, 2020 at 6:49 am
PrabhuManickam
SubscriberOh, Then it's tough to do UVL (Triangular Load) in Ansys workbench.
July 13, 2020 at 6:47 pm
peteroznewman
Subscriber On a beam element, it would seem so. I have seen it work on solid elements.
Here is an example of the APDL code if you want to try that, but I can't help you.
July 25, 2020 at 4:31 am
PrabhuManickam
SubscriberSure,
I will try this one.Â
- The topic ‘1D Analysis – ANSYS Workbench (UVL)’ is closed to new replies.
6485
