April 27, 2026 at 10:18 am
ss135
SubscriberHi All,
I've assigned following voltage to my PCB imported in HFSS solver. While analyzing, it showed error "No excitation are defined". Do I need to define 't' ? If yes, how to do that?
I've observed one more thing, since this voltage is a time dependent one, how can evaluated value come out to be exact values when t is not defined at any instant?
April 27, 2026 at 11:07 pm
Takeshi Itadani
Ansys EmployeeFirst, is the variabletdefined as a Local Variable in the Design Properties? If not, the variabletwill be undefined and an error will occur.ÂAlso, are you performing a Transient analysis? HFSS cannot perform time-domain analysis if it is not a Transient analysis, and in a Transient analysis, the variable representing time is reserved asTimein the Intrinsic Variables.ÂNormally, when using an arbitrary time waveform as the excitation source in HFSS Transient analysis, the correct procedure is to select Transient in Solution Type, Composite Excitation in Options, and then select Dataset to represent the time waveform as the excitation source.Â
