April 2, 2026 at 2:53 pm
marcberthoud
SubscriberI'm in AEDT and would like to have a cross section to analyze the fields and see the mesh. Web search indicates I have to select the object I'm interested in then go to ... -> Surface -> Section.. But the sections is NOT AVAILABLE. What is the simplest way to get a cross section to be able to see fields and meshing inside a cube? Screenshot is at
April 2, 2026 at 11:41 pm
Takeshi Itadani
Ansys EmployeeThe easiest method is to use the Clip Plane function.
First, create the plane you want to display the cross-section on by selecting the menu Draw > Plane.
With the plane you just created selected under Planes in the Model tree, select the menu View > Clipping > Add Clip Plane.
In the Clip Plane dialog box, planes with "Enabled" checked will be enabled for cross-section display. Checking "Flip" will reverse the direction of the cross-section.
April 5, 2026 at 6:42 pm
April 6, 2026 at 12:26 am
5899
1306
