LS Dyna
LS Dyna
ICFD_Model_Viscoelasticity
    • Dennis Chen
      Hello, I am looking for some quick guidance on how to properly tie ICFD_Model_VIscoelasticity (oldboyd-B model) to a fluid material inside LS-Dyna.
      Would mat_elastic_fluid work if I just want to apply a pressure to a body that's made of this material (hot and flowing) and I want to evaluate how much this material is squeezed out.   Would this have to be a ICFD problem (Given the ICFD keyword)? so I have to run it as FSI in dyna?  How do I properly define the fluid material?
      I appreciate any guidance you guys can provide, thank you!
      A general simple example model is MASSIVELY appreciated. zchen6@gatech.edu is my email.
    • igandiko
      ICFD_MODEL_VISCOELASTIC -> the viscoelastic model must  be referenced in ICFD_MAT. Please see documentation on both cards.
      Please see below conference paper shows lid-driven cavity flow of Oldroyd-B fluid. I will send the input files to zchen6@gatech.edu.
      https://www.dynalook.com/conferences/17th-international-ls-dyna-conference-2024/biomedical-healthcare/solomenko_ansys.pdf
