3D Design
3D Design
Convert Entire Solid Body to Volume in Spaceclaim
    • Spencejo
      Hi all,
      I am trying to convert a whole solid body model I have into a volume. So far, I have been unable to generate this using the Volume Extract tool and have only made partial sections of it into a volume. Is there a way to simply convert the entire geometry into a volume? I'll attach an image of the model to this post. Thanks!
      -Spencer
    • Kalyan Goparaju
      Hello Spencer,
      Can you please insert the image into your post instead of adding it as an attachment?
      Thank you,
      Kalyan
    • Kalyan Goparaju
      Hello Spencer,
      If the solid body itself is the geometry that you want to use for the CFD simulation, then just directly import .scdoc file into the appropriate meshing software and continue the process. Volume extraction is only required when the solid body you have makes up only the boundaries/walls of your geometry and your fluid domain needs to be extracted based on these walls.
      Thanks,
      Kalyan
    • Spencejo
      Hi Kalyan,
      That is indeed the case with this solid, I imported it as you said and it worked! Thank you very much.
      -Spencer
    • Kalyan Goparaju
      Hello Spencer,
      I am glad it helped. Can you please mark the answer as 'Is Solution' so that it can help others.
      Thank you,
      Kalyan
Viewing 5 reply threads
  • The topic ‘Convert Entire Solid Body to Volume in Spaceclaim’ is closed to new replies.
