Ansys Products
Ansys Products
Problem with MS VC++ 2017 Redistributable
    • Ferdinando1995
      I can't solve this problem on my laptop, i have already reinstalled, disabled antivirus to reinstallation, and installed all Microsoft visual C++. What can I do next?
      Start Installation: ter jun 2 15:40:23 2020
      Revision: 2020 R1
      Platform specifics:
      Windows
      Username of Installer: FERDINANDOFerdinando Freire
      User Has Administrator Privileges
      C:Users55219AppDataLocalTempans_install_tmp9172instcore.exe -usetempdir C:Users55219AppDataLocalTempans_install_tmp9172 -launchdir "C:Users55219DesktopInstalador Ansys" -admin
      Initial mount directory:
      Installation Directory:
      C:Program FilesANSYS IncANSYS Student
      Windows x64
      Date verification complete...No conflicts found.
      The installation will copy the prerequisite setup files from the media in case you need to reconfigure later or if you need to configure client machines for products installed to a network share.
      This may take a while ...
      Successfully copied prerequisites from media.
      You're missing required prerequisites.
      Installing MS VC++ 2017 Redistributable x86
      Installing MS VC++ 2017 Redistributable x64
      There was a problem installing the following prerequisites:
      Would you like to re-try?
      If the installation of the prerequisites fails after multiple attempts, please attempt to install the prerequisites yourself, or contact your system administrator.
    • tsiriaks
      When you tried to manually install these two
      what did it say ?
    • Ferdinando1995
      It gaves three options: Repair, Uninstall, and close. I tried those options but it still doesn't work.
      When i click to install MS VC++ 2017, it automatically install 2015-2019 versions.
    • tsiriaks
      You will have to figure out what software (or Windows update) installed this MSVC++ 2015-2019 on your machine.
      Then, see if is possible to uninstall this for a while, so that you can run the installation of these two
      Make sure they are successful. Then, you can re-install the MSVC++ 2015-2019 (with exact same build) back.
    • Ferdinando1995
      I got it! I discorvered what was my problem.
      I've uninstalled all the 2015-2019 versions, allthough i found a 2019 version installed that i had not found before and uninstalled it. Then i run again the setup and i get it, finally!
      Note: i had to copy the "prereq" files from the installer folder to: C:Program FilesANSYS IncANSYS Studentv201prereq
    • tsiriaks
      That's great ! Glad to hear that helps with the issue. Thank you for the confirmation.
Viewing 5 reply threads
  • The topic ‘Problem with MS VC++ 2017 Redistributable’ is closed to new replies.
