Temperature contour plot on a 2D domain
    • ham_nola
      I have the following contour plot. Although the "filled" option is selected, yet the post-processing in Fluent shows some missing area. The solution I'm expecting is how to ensure it fills all the domains.
      Even if I select the surfaces, it shows the contour plot on the mesh. It the second plot.
      I appreciate the help. Thank you.
      Best regards,
      Hamed.
    • Karthik Remella
      Administrator
      If this is a 2D simulation, could you please deselect all surfaces, make sure that the Global Range option is checked, and plot the contour? Could you also check 'Boundary Values' and try?
      Thanks.
      Karthik
    • ham_nola
      Thank you for the response Karthik. These are contour plots is the same order:
      a. Deselected all surfaces and Global range turned ON
      b. Deselected all surfaces. Global range and Boundary range turned ON.
      Thank you for your help.
      Best regards
      Hamed
    • Rahul Kumar
      Hello Hamed,
      Is it just the temperature contour or is this occurring while plotting pressure contours too?
    • ham_nola
      Thank you for replying Rahul.
      I found that this occurs when I used "Banded" in the contour plot. However, when I change it to "smooth", I get the following. Can you please explain this?
      Thank you.
      Best regards
      Hamed.
    • DrAmine
      Which release version? Other fields affected?
    • ham_nola
      2020 R1
    • ham_nola
      I plot pressure, velocity, volume fraction. They are fine.
    • Rahul Kumar
      When you are using "Banded", can you uncheck "Node Values" under the Options menu and plot the contour.
    • ham_nola
      Thank you, Rahul. Selecting banded and turning off the node values resolved the issue.
      Could you please explain it as well? Thank you.
      Best regards
      Hamed
Viewing 9 reply threads
  • The topic ‘Temperature contour plot on a 2D domain’ is closed to new replies.
