September 12, 2025 at 4:18 pm
giuseppe.iacolino
SubscriberDear all,
I am currently running a low-velocity impact simulation in ANSYS LS-DYNA. The structure is clamped at the base using mechanical clamps, where I have applied a force of 50 N to hold it in place.
The issue is that in the current results, this force starts acting exactly at the beginning of the simulation. However, in reality, the clamps are already applying this force before the impact occurs. What I would like to achieve is a setup where the force is already acting on the structure before the impact test starts, so that the structure is properly fixed at the base (without generating unwanted bending effects) when the impact begins.
Do you know if there is a way in LS-DYNA to ensure that this boundary condition is applied in a preloaded state, i.e., the force acts on the structure before the actual impact simulation starts?
Any suggestions would be greatly appreciated.
Best regards
September 15, 2025 at 9:34 am
Nanda
Ansys EmployeeHello User,
Have you explored dynamic relaxation in LS-DYNA?
Preload — Welcome to LS-DYNA Examples
Nanda.
Introducing Ansys Assistant a 24/7 AI-powered virtual assistant for active Ansys academic customers.
Have a look at our public help documentation website: Ansys Help
For more exciting courses and certifications, hit this link: Ansys Innovation Courses | ANSYS Innovation Space
- The topic ‘Question on Preloading Boundary Conditions in LS-DYNA Impact Simulation’ is closed to new replies.
6760
1330
1097
