May 18, 2020 at 9:04 pm
Mario95
Subscriber -
May 19, 2020 at 5:19 am
Keyur Kanade
Ansys EmployeeThere are certain videos on youtube about hex mesh for airfoil.Â
use similar strategy for this model as well.Â
you can use symmetry instead of full model.Â
Keyur
If this helps, please mark this post as 'Is Solution' to help others.
May 19, 2020 at 2:48 pm
Mario95
SubscriberIs there a way to make a structure mesh out of it?
May 20, 2020 at 1:48 am
Mario95
SubscriberIf I do symmetry I will not be able to model angle of attack because the flow will not be the same in both symmetry planes right?
May 20, 2020 at 5:38 am
Keyur Kanade
Ansys Employeeif it makes angle to y axis only then symmetry can handle it.Â
Keyur
May 20, 2020 at 1:34 pm
Mario95
SubscriberPerfect thanks for your time
- The topic ‘Mesh generation of a rocket nose cone’ is closed to new replies.
5884
1306
