July 25, 2025 at 5:35 am
mukattash
SubscriberÂ
Hello Everyone,
I am doing a non linear analysis for a masonry shear wall. I am applying the vertical and horizontal load. the model terimenated at 1.22 sec without failure. I increased the termination time still the same curve. I am getting normal termination but not softening happen. Is is a mesh or somthing other problem.
July 25, 2025 at 7:25 am
Dennis Chen
Subscribercan you share your d3hsp, message/mes0000 and output file?  There should be something in there that tells you what happened.  turn off mass scaling if there's any as well to see if that's the reason (i've seen it happen before).Â
July 25, 2025 at 10:26 am
mukattash
SubscriberÂ
How to share the files. I am not using any mass scalling also
July 25, 2025 at 10:37 am
July 25, 2025 at 10:43 am
mukattash
SubscriberIf above link will not work..
https://www.dropbox.com/t/YH1rcoMOmUFSfhjf
July 26, 2025 at 8:44 am
July 26, 2025 at 11:52 am
mukattash
Subscriberthe terminaton time is 1.2 sec. I was just wundering why there is no drop in the curve after the failure happen in the masonry shear wall.
3582
1193
1086
1063
952
