June 25, 2025 at 5:03 pm
mancs8610
SubscriberHi,
In the mentioned software (Maxwell RMxprt, Electronics Desktop 2024 R2), the program crashes with an error message when I try to set certain motor parameters – specifically the winding wire size and core steel type.
Does anyone know what could be causing this issue or how to fix it?Thanks in advance for any help!
June 26, 2025 at 12:39 pm
Ivonne Marti
Ansys EmployeeHi,
If this issue did not occur previously, please check whether your computer has received any updates in the past few days. Additionally, try updating your graphics card drivers by installing the latest available version.
I hope it helps
September 19, 2025 at 11:15 am
mj478
SubscriberHi,Â
I have the same problem with ansys 2025 R2 and 2023 R1.Â
I have reinstalled it multiple times but it did not solved.
I appreciate if you could find any solution for this
October 29, 2025 at 5:22 am
nathan.lu
Subscriberhello i am facing the same anysy carck issue of 2024R2, When do the material core steel material setting, do you know how to solve this issue.
6635
1312
