April 26, 2020 at 10:43 pm
Furkanbatesli
SubscriberHello everyone,
I'm working on static structural analysis of 16 tons bogie axle. I have completed all contacts and mesh processes. But I see ''An unknown error occurred during solution. Check the Solver Output on the Solution Information object for possible causes.'' type of error.Â
There are a lot of entry about this situation. I tried everything but not working. ( core number :2 , turn off distribute solution etc. )
Could you help me please ?
I attached solution information text.Â
Thank you.
April 26, 2020 at 11:32 pm
peteroznewman
Subscriber*** WARNING *** CP = 18.875 TIME= 015:06
Element 1434453 has a radius/thickness ratio of 3.00000021 (minimum
radius of curvature of 30.0000021 and a maximum thickness of 10 ).
The number of ERROR and WARNING messages exceeds 200.
Additional messages suppressed. See (
ansys
proje_ProjectScratchScr9496file.err ) for suppressed messages.
NUMBER OF WARNING MESSAGES ENCOUNTERED= 213
NUMBER OF ERROR MESSAGES ENCOUNTERED= 2
***** PROBLEM TERMINATED BY INDICATED ERROR(S) OR BY END OF INPUT DATA *****
You have so many warning messages about element shape that the error is not included in this file. It is in another file. Please show the actual error message.
April 28, 2020 at 6:45 pm
Furkanbatesli
SubscriberAnother file ? Where do I find actual error. I don't understand.
April 28, 2020 at 7:17 pm
Furkanbatesli
Subscriber''One or more parts were found to be unmodified so smart updated.'' I always see this warning message. Could this error be due to this warning message ?Â
April 29, 2020 at 12:35 am
peteroznewman
SubscriberIgnore that message about smart updated, it has nothing to do with your problem.
In Mechanical, right click on Solution and in the pop-up, you can Open Solver Files Directory. In that directory is file0.err which has the error in it.
May 2, 2020 at 9:44 pm
Furkanbatesli
SubscriberThanks a lot Mr. Peter.
- The topic ‘An unknown error occurred during solution.’ is closed to new replies.
5874
1306
