May 21, 2025 at 3:42 pm
s281303
SubscriberI have to analyse local loads on a carbon fibre panel. I executed the run but I cannot plot the stress of each layer. The software plots just the mean stresses (Von Mises, Tresca...) but not the one of each layer I need.
I used MAT054 to define the mat properties and then Part-Composite for the layer layout [0/90/+-45]_2
May 22, 2025 at 5:41 pm
Reno Genest
Ansys EmployeeHello,
Have you set MAXINT in *DATABASE_EXTENT_BINARY to the number of layers in your layup to output results for each through the thickness integration point?
You can also set CMPFLG=1 in *DATABASE_EXTENT_BINARY to write stress and strain results in the material coordinate system.
Have a look at the following 2 presentations on composites in LS-DYNA:
https://ftp.lstc.com/anonymous/outgoing/support/FAQ_kw/composites/mat_comp.pdf
https://ftp.lstc.com/anonymous/outgoing/support/PRESENTATIONS/lsprepostcomposite.pdf
Let me know how it goes.
Reno.
May 22, 2025 at 5:59 pm
s281303
SubscriberThank you very much Reno, now I'm able to plot the local stresses 👍
May 22, 2025 at 6:18 pm
3145
1007
935
858
792
